주요 콘텐츠로 건너뛰기
Ryobi P501G Battery Replacement
  1. Ryobi P501G Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the battery at the base of the RYOBI P501G.
  2. Ryobi P501G Battery Replacement: 2 단계, 이미지 1/3 Ryobi P501G Battery Replacement: 2 단계, 이미지 2/3 Ryobi P501G Battery Replacement: 2 단계, 이미지 3/3
    • Place your thumb and forefinger on opposite sides at the base of the RYOBI P501G, where the buttons to release the battery are located.
    • Click on the buttons to release the latches holding the battery in place and connected.
결론
Eeshan Mishra
회원 가입일: 01/24/19
424 평판
안내서 4개 작성하였습니다
Cal Poly, Team S1-G2, Maness Spring 2019 Cal Poly, Team S1-G2, Maness Spring 2019 회원
CPSU-MANESS-S19S1G2
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
Replacement for Ryobi P501G Cordless Drill Battery
Type: Li-ion
Volt: 18V
Capacity: 6000mAh
Color: Black
Weight: 898g
Dimension: 135.70 x 76.00 x 107.30mm
This drill battery for Ryobi P501G is 100% compatible and will meet or exceeds original specification. This P501G replacement battery made by Amstron has been tested for safety and designed for high performance. go to view more at https://www.drillbattery.co.uk/batterysa...
Drillbatterycomau - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 464
