주요 콘텐츠로 건너뛰기
Ryobi P501G Shell Replacement
필요한 것
  1. Ryobi P501G Shell Replacement, Blade: 1 단계, 이미지 1/1
    • Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
  2. Ryobi P501G Shell Replacement: 2 단계, 이미지 1/2 Ryobi P501G Shell Replacement: 2 단계, 이미지 2/2
    • Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
  3. Ryobi P501G Shell Replacement: 3 단계, 이미지 1/3 Ryobi P501G Shell Replacement: 3 단계, 이미지 2/3 Ryobi P501G Shell Replacement: 3 단계, 이미지 3/3
    • Remove the four black screws holding the black bearing and remove the bearing itself.
  4. Ryobi P501G Shell Replacement: 4 단계, 이미지 1/1
    • Once the black bearing is off, remove the transparent cover of the blade.
    • Once the cover is off, remove the blade.
    • Place the new blade with the flat notches lined up with the flat notches on the motor axle.
  5. Ryobi P501G Shell Replacement, Shell: 5 단계, 이미지 1/3 Ryobi P501G Shell Replacement, Shell: 5 단계, 이미지 2/3 Ryobi P501G Shell Replacement, Shell: 5 단계, 이미지 3/3
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  6. Ryobi P501G Shell Replacement: 6 단계, 이미지 1/3 Ryobi P501G Shell Replacement: 6 단계, 이미지 2/3 Ryobi P501G Shell Replacement: 6 단계, 이미지 3/3
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
결론
Eeshan Mishra
회원 가입일: 01/24/19
424 평판
안내서 4개 작성하였습니다
Cal Poly, Team S1-G2, Maness Spring 2019 Cal Poly, Team S1-G2, Maness Spring 2019 회원
CPSU-MANESS-S19S1G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 291
