주요 콘텐츠로 건너뛰기
Ryobi P516 Top Case Replacement
필요한 것
  1. Ryobi P516 Top Case Replacement, Top Case: 1 단계, 이미지 1/2 Ryobi P516 Top Case Replacement, Top Case: 1 단계, 이미지 2/2
    • Using the 5mm hex key included at the base of the saw, loosen the set screw at the front of the saw.
    • The front guard will now slide out from the front of the saw.
  2. Ryobi P516 Top Case Replacement: 2 단계, 이미지 1/3 Ryobi P516 Top Case Replacement: 2 단계, 이미지 2/3 Ryobi P516 Top Case Replacement: 2 단계, 이미지 3/3
    • Remove the two 10mm T20 Torx screws from the front of the saw.
    • Pull out the front plate.
  3. Ryobi P516 Top Case Replacement: 3 단계, 이미지 1/3 Ryobi P516 Top Case Replacement: 3 단계, 이미지 2/3 Ryobi P516 Top Case Replacement: 3 단계, 이미지 3/3
    • Start at the middle of the device and begin to pry up the rubber grip.
    • Pull the rubber portion inside out towards the front of the saw.
  4. Ryobi P516 Top Case Replacement: 4 단계, 이미지 1/1
    • Remove all twelve 14mm T20 Torx screws from the main case of the device.
  5. Ryobi P516 Top Case Replacement: 5 단계, 이미지 1/3 Ryobi P516 Top Case Replacement: 5 단계, 이미지 2/3 Ryobi P516 Top Case Replacement: 5 단계, 이미지 3/3
    • Remove the four 35mm Phillips #2 screws.
    • Pry the two case halves apart starting at the middle of the saw.
    • Watch out for any loose parts from inside the saw that may fall out during this step.
  6. Ryobi P516 Top Case Replacement: 6 단계, 이미지 1/1
    • Continue splitting the case until the top piece of the case is free and set it aside.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Cameron Davis
회원 가입일: 09/16/19
255 평판
안내서 1개 작성함
댓글 2개
P516 blade locking parts
Bill clark - 답글
P516 blade locking parts breakdown, please ?
Bill clark - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 27
30일 전: 67
전체 시간: 4,174
