주요 콘텐츠로 건너뛰기
Ryobi RJ1861V Motor Housing Replacement
필요한 것
  1. Ryobi RJ1861V Motor Housing Replacement, Trigger Assembly: 1 단계, 이미지 1/1
    • Use a Torx T20 screwdriver to remove the nine 16.5 mm screws around the trigger assembly.
  2. Ryobi RJ1861V Motor Housing Replacement: 2 단계, 이미지 1/2 Ryobi RJ1861V Motor Housing Replacement: 2 단계, 이미지 2/2
    • Use a Torx T20 screwdriver to remove the two 16.5 mm screws near the trigger.
  3. Ryobi RJ1861V Motor Housing Replacement, Motor Housing: 3 단계, 이미지 1/1
    • Use a Torx T20 bit or screwdriver to remove the six 19 mm screws securing the gear case cover.
  4. Ryobi RJ1861V Motor Housing Replacement: 4 단계, 이미지 1/2 Ryobi RJ1861V Motor Housing Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #2 bit or screwdriver to remove the four 37 mm screws from the top and the bottom of the gear case.
    • Once these 4 screws are removed, you have access to the motor assembly.
결론
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 137
