주요 콘텐츠로 건너뛰기
Ryobi RJ1861V Saw Bar Assembly Replacement
필요한 것
  1. Ryobi RJ1861V Saw Bar Assembly Replacement, Saw Bar Assembly: 1 단계, 이미지 1/1
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Saw Bar Assembly Replacement: 2 단계, 이미지 1/2 Ryobi RJ1861V Saw Bar Assembly Replacement: 2 단계, 이미지 2/2
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Saw Bar Assembly Replacement: 3 단계, 이미지 1/1
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Saw Bar Assembly Replacement: 4 단계, 이미지 1/1
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Saw Bar Assembly Replacement: 5 단계, 이미지 1/1
    • Remove the backside panel.
  6. Ryobi RJ1861V Saw Bar Assembly Replacement: 6 단계, 이미지 1/1
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Saw Bar Assembly Replacement: 7 단계, 이미지 1/1
    • Lift the assembly bar up and out of the chassis.
결론
Ryan Quinlivan
회원 가입일: 04/08/19
306 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 31
전체 시간: 870
