주요 콘텐츠로 건너뛰기
Ryobi RJ1861V Saw Gear Assembly Replacement
필요한 것
  1. Ryobi RJ1861V Saw Gear Assembly Replacement, Saw Bar Assembly: 1 단계, 이미지 1/1
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Saw Gear Assembly Replacement: 2 단계, 이미지 1/2 Ryobi RJ1861V Saw Gear Assembly Replacement: 2 단계, 이미지 2/2
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Saw Gear Assembly Replacement: 3 단계, 이미지 1/1
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Saw Gear Assembly Replacement: 4 단계, 이미지 1/1
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Saw Gear Assembly Replacement: 5 단계, 이미지 1/1
    • Remove the backside panel.
  6. Ryobi RJ1861V Saw Gear Assembly Replacement: 6 단계, 이미지 1/1
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Saw Gear Assembly Replacement: 7 단계, 이미지 1/1
    • Lift the assembly bar up and out of the chassis.
  8. Ryobi RJ1861V Saw Gear Assembly Replacement, Assembly Bar Bearing: 8 단계, 이미지 1/1
    • Begin with the top of the device facing up.
  9. Ryobi RJ1861V Saw Gear Assembly Replacement: 9 단계, 이미지 1/1
    • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
  10. Ryobi RJ1861V Saw Gear Assembly Replacement: 10 단계, 이미지 1/1
    • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
  11. Ryobi RJ1861V Saw Gear Assembly Replacement, Saw Gear Assembly: 11 단계, 이미지 1/1
    • After you remove the bearing, stand the device with the gear assembly facing up.
  12. Ryobi RJ1861V Saw Gear Assembly Replacement: 12 단계, 이미지 1/1
    • The gear assembly will be covered in industrial lubricant, so wipe away an excess with a rag to reveal three screws.
  13. Ryobi RJ1861V Saw Gear Assembly Replacement: 13 단계, 이미지 1/1
    • Remove three screws with a Torx bit and screw driver.
  14. Ryobi RJ1861V Saw Gear Assembly Replacement: 14 단계, 이미지 1/1
    • Rotate the device 180 degrees and apply pressure to the gear assembly through the small hole, extra force may be needed in this step to break it loose.
  15. Ryobi RJ1861V Saw Gear Assembly Replacement: 15 단계, 이미지 1/1
    • Once the gear assembly has broken free rotate the device again and lift it out of the gear housing.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Morgan Doyle
회원 가입일: 04/08/19
316 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 16
전체 시간: 854
