주요 콘텐츠로 건너뛰기
Ryobi RS290G Bearing Cap Assembly Replacement
필요한 것
  1. Ryobi RS290G Bearing Cap Assembly Replacement, Bearing Cap Assembly: 1 단계, 이미지 1/2 Ryobi RS290G Bearing Cap Assembly Replacement, Bearing Cap Assembly: 1 단계, 이미지 2/2
    • Using a TR20 Torx security screwdriver, remove the four 6mm screws.
    • Make sure to hold the backing pad firmly to prevent spinning.
  2. Ryobi RS290G Bearing Cap Assembly Replacement: 2 단계, 이미지 1/1
    • After removing the backing pad, carefully pull on the rubber brake to remove it from the housing assembly.
  3. Ryobi RS290G Bearing Cap Assembly Replacement: 3 단계, 이미지 1/1
    • Using a TR 20 Torx security screwdriver, remove the single 3mm screw in the center of the bearing cap assembly.
    • Make sure to use pliers or another tool to prevent the fan from spinning, and use a torque wrench or torque screwdriver as the screw is secured with Loctite (a compound to prevent it from loosening).
  4. Ryobi RS290G Bearing Cap Assembly Replacement: 4 단계, 이미지 1/1
    • Remove the bearing cap.
    • You may keep the spring washer and washer for reuse if they are not worn/damaged.
결론
To reassemble your device, follow these instructions in reverse order. Make sure to tighten down properly to avoid loose or traction pad issues.
Daniel
회원 가입일: 09/17/19
639 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 519
