주요 콘텐츠로 건너뛰기
Ryobi RS290G Brush Assembly Replacement
필요한 것
  1. Ryobi RS290G Brush Assembly Replacement, Top Cap: 1 단계, 이미지 1/1
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
  2. Ryobi RS290G Brush Assembly Replacement: 2 단계, 이미지 1/1
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
  3. Ryobi RS290G Brush Assembly Replacement: 3 단계, 이미지 1/1
    • Remove the top cap.
  4. Ryobi RS290G Brush Assembly Replacement, Switch Trigger: 4 단계, 이미지 1/1
    • Remove the switch trigger.
  5. Ryobi RS290G Brush Assembly Replacement, Brush Assembly: 5 단계, 이미지 1/2 Ryobi RS290G Brush Assembly Replacement, Brush Assembly: 5 단계, 이미지 2/2
    • Slide the power switch out of the housing assembly by carefully gripping the power switch and slide upward from the base.
  6. Ryobi RS290G Brush Assembly Replacement: 6 단계, 이미지 1/1
    • Remove the two 16mm Phillips #2 screws from the inner housing assembly.
  7. Ryobi RS290G Brush Assembly Replacement: 7 단계, 이미지 1/1
    • Remove the two 14mm Phillips #2 screws from the cord clamp.
  8. Ryobi RS290G Brush Assembly Replacement: 8 단계, 이미지 1/1
    • Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
  9. Ryobi RS290G Brush Assembly Replacement: 9 단계, 이미지 1/2 Ryobi RS290G Brush Assembly Replacement: 9 단계, 이미지 2/2
    • Slide out both brush assemblies from the inner housing assembly.
  10. Ryobi RS290G Brush Assembly Replacement: 10 단계, 이미지 1/1
    • Slide off the disconnect terminal for the brush assembly (white lead).
  11. Ryobi RS290G Brush Assembly Replacement: 11 단계, 이미지 1/1
    • Slide off the disconnect terminal for the brush assembly (black lead).
결론
Daniel
회원 가입일: 09/17/19
639 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 730
