주요 콘텐츠로 건너뛰기
Ryobi RS290G Motor Replacement
필요한 것
  1. Ryobi RS290G Motor Replacement, Top Cap: 1 단계, 이미지 1/1
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
  2. Ryobi RS290G Motor Replacement: 2 단계, 이미지 1/1
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
  3. Ryobi RS290G Motor Replacement: 3 단계, 이미지 1/1
    • Remove the top cap.
  4. Ryobi RS290G Motor Replacement, Switch Trigger: 4 단계, 이미지 1/1
    • Remove the switch trigger.
  5. Ryobi RS290G Motor Replacement, Motor: 5 단계, 이미지 1/1
    • Remove the two 16mm Phillips #2 screws from the inner housing assembly.
  6. Ryobi RS290G Motor Replacement: 6 단계, 이미지 1/1
    • Remove the two 14mm Phillips #2 screws from the cord clamp.
  7. Ryobi RS290G Motor Replacement: 7 단계, 이미지 1/2 Ryobi RS290G Motor Replacement: 7 단계, 이미지 2/2
    • Slide the power switch out of the housing assembly.
  8. Ryobi RS290G Motor Replacement: 8 단계, 이미지 1/1
    • Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
  9. Ryobi RS290G Motor Replacement: 9 단계, 이미지 1/2 Ryobi RS290G Motor Replacement: 9 단계, 이미지 2/2
    • Slide off the disconnect terminal for the switch (red lead) from the power switch using the flat end of a spudger.
  10. Ryobi RS290G Motor Replacement: 10 단계, 이미지 1/2 Ryobi RS290G Motor Replacement: 10 단계, 이미지 2/2
    • Slide out the brush assembly with the black lead from the inner housing assembly.
  11. Ryobi RS290G Motor Replacement: 11 단계, 이미지 1/1
    • Slide off the disconnect terminal for the brush assembly (black lead) from the brush assembly.
    • You may need an ESD-safe flat edge tool, such as a spudger, to help slide off the disconnect terminal. Be careful not to damage the pieces or yourself.
  12. Ryobi RS290G Motor Replacement: 12 단계, 이미지 1/1
    • Remove the armature assembly, with the motor, out of the inner housing assembly.
  13. Ryobi RS290G Motor Replacement: 13 단계, 이미지 1/3 Ryobi RS290G Motor Replacement: 13 단계, 이미지 2/3 Ryobi RS290G Motor Replacement: 13 단계, 이미지 3/3
    • Replace the motor (also known as field assembly).
결론
Daniel
회원 가입일: 09/17/19
639 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 8
전체 시간: 906
