주요 콘텐츠로 건너뛰기
Ryobi RS290G Power Cord Replacement
필요한 것
  1. Ryobi RS290G Power Cord Replacement, Top Cap: 1 단계, 이미지 1/1
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
  2. Ryobi RS290G Power Cord Replacement: 2 단계, 이미지 1/1
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
  3. Ryobi RS290G Power Cord Replacement: 3 단계, 이미지 1/1
    • Remove the top cap.
  4. Ryobi RS290G Power Cord Replacement, Switch Trigger: 4 단계, 이미지 1/1
    • Remove the switch trigger.
  5. Ryobi RS290G Power Cord Replacement, Power Cord: 5 단계, 이미지 1/1
    • Remove the two 16mm Phillips #2 screws from the inner housing assembly.
  6. Ryobi RS290G Power Cord Replacement: 6 단계, 이미지 1/1
    • Remove the two 14mm Phillips #2 screws from the cord clamp.
  7. Ryobi RS290G Power Cord Replacement: 7 단계, 이미지 1/2 Ryobi RS290G Power Cord Replacement: 7 단계, 이미지 2/2
    • Slide the power switch out of the housing assembly, carefully gripping the switch and pulling it upward.
  8. Ryobi RS290G Power Cord Replacement: 8 단계, 이미지 1/2 Ryobi RS290G Power Cord Replacement: 8 단계, 이미지 2/2
    • Remove the black lead from the power switch using a spudger.
  9. Ryobi RS290G Power Cord Replacement: 9 단계, 이미지 1/1
    • Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
  10. Ryobi RS290G Power Cord Replacement: 10 단계, 이미지 1/2 Ryobi RS290G Power Cord Replacement: 10 단계, 이미지 2/2
    • Slide out the brush assembly with the white lead from the inner housing assembly.
  11. Ryobi RS290G Power Cord Replacement: 11 단계, 이미지 1/1
    • Remove the white lead from the brush assembly.
  12. Ryobi RS290G Power Cord Replacement: 12 단계, 이미지 1/2 Ryobi RS290G Power Cord Replacement: 12 단계, 이미지 2/2
    • Slide the bend relief off of the old power cord to reuse on the new power cord if there is no damage.
결론
To reassemble your device, follow these instructions in reverse order. Make sure to perform an operational check after reassembling.
Daniel
회원 가입일: 09/17/19
639 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 22
전체 시간: 422
