소개
The fan in this blower is succeptible to breaking if small rocks or other small solid objects are sucked into the fan assembly. This guide outlines step-by-step how to replace this fan.
필요한 것
Once the handle has been separated, the blower shaft with detach from the motor housing. Slide the blower shaft out of the motor housing and set aside.
I can't get it separated for the life of me without going nuclear on it. Feels glued together.
Once the blower shaft is detached, the fan will be visible. Use a ratchet with a 1/2" socket to remove the 1/2" nut securing the fan to the motor. This nut is reverse thread so turning it clockwise will loosen it. The fan will also need to be secured so that it does not spin as the nut is being loosened.
Slide blower shaft back into motor housing, close handle back around blower shaft and motor housing, and screw all 9 screws back into their location.
Take leaf blower outside before operating to evaluate repair success.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 7개
My blower is not like yours. Mine like a fun has corn shaped. How to replace this fun. I need your help.
Thanks for the tip, mine is a cordless 18 v and it's slightly more difficult then shown but not impossible!!
It's all plastic and kinda worried about breaking something. I've had mine like for almost 2 yrs. I was using it and barely bumped the wall and the blade just exploded….Really crazy weird.
Thanks for the help.
Cannot find the correct part on the internet anywhere. Mine is orange and flat on the back side; not coned & green as shown in your tutorial.
Jan Dru Basehart
Jan I believe mine was orange originally as well. I would try to contact their parts department to ensure it will work before ordering though.
Recently stopped running - fan isn’t physically damaged that I can see. Thought I needed a new battery, but new battery didn’t fix. any ideas if this is symptomatic of a bad fan? anything else?
Adam Frank - 답글
For anyone looking for the fan, you can see from the parts list (https://ryobipower.ordertree.com/media/m...) that the part is 529410003 https://ryobipower.ordertree.com/catalog...
Chris Rink - 답글
