주요 콘텐츠로 건너뛰기
Ryobi VC120 Motor Replacement
필요한 것
  1. Ryobi VC120 Motor Replacement, Filter: 1 단계, 이미지 1/1
    • Pull the black nose off of the body of the vacuum, by pushing in the orange button closest to the nose.
  2. Ryobi VC120 Motor Replacement: 2 단계, 이미지 1/2 Ryobi VC120 Motor Replacement: 2 단계, 이미지 2/2
    • Grab the filter with two fingers and slide it out.
  3. Ryobi VC120 Motor Replacement, Motor: 3 단계, 이미지 1/2 Ryobi VC120 Motor Replacement, Motor: 3 단계, 이미지 2/2
    • Using a Philips head screwdriver, remove the four screws located on the side panel of the vacuum.
    • There are two types of screws on this device. You may want to use a magnetic screw pad to organize your screws to be sure they return to their designated holes.
    • 4x 19.1mm
    • 1x 14.3mm
    • Once the screws are removed, you should be able to separate the side panel from the rest of the device.
  4. Ryobi VC120 Motor Replacement: 4 단계, 이미지 1/3 Ryobi VC120 Motor Replacement: 4 단계, 이미지 2/3 Ryobi VC120 Motor Replacement: 4 단계, 이미지 3/3
    • Pull your motor out, and remove the black and red cables from the motor by hand.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Allison Schoch
회원 가입일: 09/16/15
689 평판
안내서 4개 작성하였습니다
IUPUI, Team 2-4, Baechle Fall 2015 IUPUI, Team 2-4, Baechle Fall 2015 회원
IUPUI-BAECHLE-F15S2G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 783
