필요한 것
Unscrew the two phillips head screws. Use the reversible screwdriver that came with the car.
Pull the cover up and slightly to the right.
Here we have to replace the filter. Lift the filter up. It comes off without difficulty.
Clean all of the rubbish and insects that are inside.
Place the new filter, fitting the rubber contour with the gap.
Fit the two tabs in their places.
Once you've done that, put the two screws into their places and tightly screw them in. Finally, check to see that they are completely screwed in.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Mr. Bean님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
