소개
This guide will help you replace the back cover of you controller. You’ll only need a Phillips #000 screwdriver to complete this guide.
필요한 것
Hold the controller with the bottom plate facing up, and gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
Remove the screws on the back of the controller with the Phillips #000 screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
