주요 콘텐츠로 건너뛰기
SEGA Genesis Flashback Motherboard Replacement
필요한 것
  1. SEGA Genesis Flashback Motherboard Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Scratch off the right-hand side of the sticker at the center of the bottom case using the spudger until the screw is visible.
    • Remove this screw with the Phillips #000 screwdriver.
  2. SEGA Genesis Flashback Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two visible screws on the bottom with the Phillips #000 screwdriver.
  3. SEGA Genesis Flashback Motherboard Replacement: 3 단계, 이미지 2개 중 1개 SEGA Genesis Flashback Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Use your fingers to peel off the four corner rubber feet on the bottom.
    • Use the Phillips #000 screwdriver to remove the four screws beneath the rubber feet.
  4. SEGA Genesis Flashback Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Flip the case to its upright position.
    • Place one hand on the bottom plate of the case and one on the top plate. Gently pull apart the two plates by tilting the top plate about the front of the device. Treat the front of the device as a hinge.
    • Remove the back cover from the device.
    • Be sure not to rip the wire connection of the LED bulb that is still connected to the bottom plate.
  5. SEGA Genesis Flashback Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Unscrew the LED board on the inside of the top plate with the Phillips #000 screwdriver.
    • Note: The top plate is no longer needed for the next steps, so you can feel free to set it aside until reassembly.
  6. SEGA Genesis Flashback Motherboard Replacement: 6 단계, 이미지 2개 중 1개 SEGA Genesis Flashback Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Use the Phillips #000 screwdriver to remove the five screws circled in the provided picture.
    • The tan board can now detach from the rest of the case, as pictured, but you can feel free to leave it in place for now.
    • CAUTION: Do not disconnect the tan power switch board from the grey ribbon cables.
  7. SEGA Genesis Flashback Motherboard Replacement: 7 단계, 이미지 2개 중 1개 SEGA Genesis Flashback Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the smaller screws located on the green motherboard with the Phillips #000 screwdriver.
    • Remove the two larger screws holding down the game cartridge slot with the Phillips #1 screwdriver.
  8. SEGA Genesis Flashback Motherboard Replacement: 8 단계, 이미지 3개 중 1개 SEGA Genesis Flashback Motherboard Replacement: 8 단계, 이미지 3개 중 2개 SEGA Genesis Flashback Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Gently remove the motherboard and the connected tan power switch board from the bottom plate.
    • CAUTION: Be sure not to rip the ribbon cables connecting the motherboard and tan power switch board.
결론
To reassemble your device, follow these instructions in reverse order. We have attached photos to assist you in replacing the LED bulb in the correct spot.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Matthew Lawler
회원 가입일: 04/19/18
252 평판
안내서 1개를 작성함
Cal Poly, Team S24-G12, Maness Spring 2018 Cal Poly, Team S24-G12, Maness Spring 2018 회원
CPSU-MANESS-S18S24G12
4 회원들
안내서 10개를 작성함
1가이드 댓글
Gday!
I recived a Sega HD Flashback 85 for Xmax. When I turned ON the game I have sound on the main menu but not when I played the game.
I went on the at@game to download there firware for the good console since my uptade I don’t have any video game anymore. I rename the file name on my SD Card like the instruction with anysucces. When I installed the SD card with the last firware and turn ON the console it update for ever without rest upload and turn ON the new update.
ERIC GUAY
ERIC GUAY - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 42
전체 시간: 2,460
