주요 콘텐츠로 건너뛰기
SG 552-1 Commando Barrel Replacement
필요한 것
  1. SG 552-1 Commando Barrel Replacement, Barrel: 1 단계, 이미지 2개 중 1개 SG 552-1 Commando Barrel Replacement, Barrel: 1 단계, 이미지 2개 중 2개
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Pull the hand guard off.
  2. SG 552-1 Commando Barrel Replacement: 2 단계, 이미지 2개 중 1개 SG 552-1 Commando Barrel Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun. There should be four total.
  3. SG 552-1 Commando Barrel Replacement: 3 단계, 이미지 2개 중 1개 SG 552-1 Commando Barrel Replacement: 3 단계, 이미지 2개 중 2개
    • Locate the button to fold over the folding stock and fold over the folding stock.
    • Using a Phillips #1 screwdriver, remove the 20mm screw located behind the folding stock.
  4. SG 552-1 Commando Barrel Replacement: 4 단계, 이미지 2개 중 1개 SG 552-1 Commando Barrel Replacement: 4 단계, 이미지 2개 중 2개
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw located directly underneath the cocking lever.
    • Remove the 8mm screw beside the one you just removed.
  5. SG 552-1 Commando Barrel Replacement: 5 단계, 이미지 2개 중 1개 SG 552-1 Commando Barrel Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
  6. SG 552-1 Commando Barrel Replacement: 6 단계, 이미지 3개 중 1개 SG 552-1 Commando Barrel Replacement: 6 단계, 이미지 3개 중 2개 SG 552-1 Commando Barrel Replacement: 6 단계, 이미지 3개 중 3개
    • Pull the barrel out from the cover.
    • Remove the pieces at the end of the barrel.
  7. SG 552-1 Commando Barrel Replacement: 7 단계, 이미지 2개 중 1개 SG 552-1 Commando Barrel Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the remaining pieces of on the ends of the barrel.
결론
작성자
5다른 기여자 명과 함께
Laura Schulz
회원 가입일: 10/05/12
1 평판
안내서 1개를 작성함
Cal Poly, Team 18-41, Regan Fall 2012 Cal Poly, Team 18-41, Regan Fall 2012 회원
CPSU-REGAN-F12S18G41
6 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 1,787
