주요 콘텐츠로 건너뛰기
SHARP EL-W53XG WriteView Battery Replacement
필요한 것
  1. SHARP EL-W53XG WriteView  Battery Replacement, Battery: 1 단계, 이미지 1/2 SHARP EL-W53XG WriteView  Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Turn off the calculator by pressing both the [2NDF ] and [ON] buttons at the same time.
  2. SHARP EL-W53XG WriteView  Battery Replacement: 2 단계, 이미지 1/1
    • Flip the calculator so that the battery cover is facing you, and it will be easy to remove.
  3. SHARP EL-W53XG WriteView  Battery Replacement: 3 단계, 이미지 1/2 SHARP EL-W53XG WriteView  Battery Replacement: 3 단계, 이미지 2/2
    • Remove the two screws securing the battery cover with the Tri-point #000 screwdriver.
    • Remove the battery cover.
    • Make sure not to remove the other screws on the calculator, just the two screws on the battery cover.
  4. SHARP EL-W53XG WriteView  Battery Replacement: 4 단계, 이미지 1/2 SHARP EL-W53XG WriteView  Battery Replacement: 4 단계, 이미지 2/2
    • Remove the worn-out LR44 battery inside using a spudger.
  5. SHARP EL-W53XG WriteView  Battery Replacement: 5 단계, 이미지 1/1
    • Gently insert the new LR44 battery in the empty battery slot.
  6. SHARP EL-W53XG WriteView  Battery Replacement: 6 단계, 이미지 1/1
    • Place and screw the battery cover on using the Tri-point #000 screwdriver.
    • Tightly screw the battery cover to prevent losing screws.
결론
Faduma Hagi
회원 가입일: 09/14/21
133 평판
안내서 1개 작성함
York University, Team 1-7, O'Regan Fall 2021 York University, Team 1-7, O'Regan Fall 2021 회원
YORK-O'REGAN-F21S1G7
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 36
전체 시간: 1,491
