주요 콘텐츠로 건너뛰기
SKIL 4235 Jigsaw Gear Replacement
필요한 것
  1. SKIL 4235 Jigsaw Gear Replacement, Disassembling SKIL 4235 Jigsaw Base plate: 1 단계, 이미지 1/3 SKIL 4235 Jigsaw Gear Replacement, Disassembling SKIL 4235 Jigsaw Base plate: 1 단계, 이미지 2/3 SKIL 4235 Jigsaw Gear Replacement, Disassembling SKIL 4235 Jigsaw Base plate: 1 단계, 이미지 3/3
    • Orient your saw so that the blade is pointing in the opposite direction of your body. Ensure that the screws circled are visible and pointing skyward. This will be the standard position of the Jigsaw for the duration of this guide.
  2. SKIL 4235 Jigsaw Gear Replacement: 2 단계, 이미지 1/1
    • Using two hands grip both side of the saw and lay on side.
  3. SKIL 4235 Jigsaw Gear Replacement: 3 단계, 이미지 1/1
    • With bottom of the base plate visible, identify one M4 screw circled in red and remove with Phillips screwdriver (some models have flathead screw, as pictured, and require flathead screwdriver).
  4. SKIL 4235 Jigsaw Gear Replacement: 4 단계, 이미지 1/1
    • After removing M4 screw, remove the base plate and place to the side. Don't forget to replace the M4 screw near the base plate during re-installation.
  5. SKIL 4235 Jigsaw Gear Replacement, Protective Frame: 5 단계, 이미지 1/3 SKIL 4235 Jigsaw Gear Replacement, Protective Frame: 5 단계, 이미지 2/3 SKIL 4235 Jigsaw Gear Replacement, Protective Frame: 5 단계, 이미지 3/3
    • Ensure that the Jigsaw is properly placed and that the blade is away from your body with the screws facing upward.
    • Identify the 10 screws circled for removal. Once all screws have been identified, use your Phillips screwdriver and begin removing them.
    • Once all screws have been removed, remove the protective frame by gripping it from both sides and lifting it skyward.
    • Be advised
    • You may need to lift with one hand and hold the rest of the saw with the other.
    • Now placing the frame off to the side you should have a clear view of all the internal working parts. Now we can begin making our repairs.
    • Be advised:If this is the first time opening up your tool, expect it to be very dirty. It is recommended you use a shamy cloth or wet rag to keep your hands clean.
    • At this point what lies in front of you should be a disassembled version of your SKIL 4235 Jigsaw.
    • Caution: Make sure your device is unplugged.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Adam Cardoso
회원 가입일: 11/12/13
357 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 4-8, Vijaybhaskar Fall 2013 UMass Dartmouth, Team 4-8, Vijaybhaskar Fall 2013 회원
UMASSD-VIJAYBHASKAR-F13S4G8
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
What recommended grease should you use for the gears? Asking for a friend 😑
b407 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 30
전체 시간: 3,080
