주요 콘텐츠로 건너뛰기
SKYTEX SP1020 Speakers Replacement
필요한 것
  1. SKYTEX SP1020 Speakers Replacement, Rear Case: 1 단계, 이미지 1/2 SKYTEX SP1020 Speakers Replacement, Rear Case: 1 단계, 이미지 2/2
    • Prior to any repairs make sure that you are familiar with the device as well as the location of its buttons and ports.
    • Turn off device prior to continuing to further steps.
  2. SKYTEX SP1020 Speakers Replacement: 2 단계, 이미지 1/3 SKYTEX SP1020 Speakers Replacement: 2 단계, 이미지 2/3 SKYTEX SP1020 Speakers Replacement: 2 단계, 이미지 3/3
    • Set the tablet back panel facing down, with the SKYTEX logo facing you. You will find that this step will start from the right side of the device.
    • Insert the plastic opening tool between the bottom seam of the back panel and the micro SD port. The tool's edge should point toward the rear panel to prevent any scratching or damage.
    • Follow up with the plastic opening tool, releasing the clips as you go all the way around the device.
  3. SKYTEX SP1020 Speakers Replacement: 3 단계, 이미지 1/1
    • The clips will be released in the order specified as the spudger tool is moved along the seam around the device.
  4. SKYTEX SP1020 Speakers Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to pry the speakers out of the rear case.
    • The rear case will now be free from the rest of the device.
  5. SKYTEX SP1020 Speakers Replacement, Speakers: 5 단계, 이미지 1/1
    • locate the speakers
  6. SKYTEX SP1020 Speakers Replacement: 6 단계, 이미지 1/2 SKYTEX SP1020 Speakers Replacement: 6 단계, 이미지 2/2
    • Use a soldering iron and desoldering braid to desolder the two sets of red and black wires.
  7. SKYTEX SP1020 Speakers Replacement: 7 단계, 이미지 1/1
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anthony Vitali
회원 가입일: 03/23/15
293 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-6, Miles Spring 2015 UMass Dartmouth, Team 1-6, Miles Spring 2015 회원
UMASSD-MILES-S15S1G6
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 106
