주요 콘텐츠로 건너뛰기
SM Santa Marin hand watch Battery Replacement
필요한 것
  1. SM Santa Marin hand watch Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Take apart the steel strap for the watch by using the round head (SIM) screwdriver. Then pull out the screw.
  2. SM Santa Marin hand watch Battery Replacement: 2 단계, 이미지 1/1
    • Remove four screws from the back cover using the Y000 screwdriver .
  3. SM Santa Marin hand watch Battery Replacement: 3 단계, 이미지 1/1
    • Remove the back cover of the watch using the opening tool.
  4. SM Santa Marin hand watch Battery Replacement: 4 단계, 이미지 1/1
    • Remove the plastic gasket from on top of the battery using the opening tool.
  5. SM Santa Marin hand watch Battery Replacement: 5 단계, 이미지 1/1
    • Loosen the battery bracket from the watch by placing the 1mm flathead screwdriver under and lifting carefully.
  6. SM Santa Marin hand watch Battery Replacement: 6 단계, 이미지 1/2 SM Santa Marin hand watch Battery Replacement: 6 단계, 이미지 2/2
    • Take the old battery out using the plastic opening tool or spudger.
결론
Aziz Zabarmawi
회원 가입일: 10/07/19
133 평판
안내서 1개 작성함
댓글 한 개
It's amazing and also work as a machenic for me
Talha - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 16
전체 시간: 899
