주요 콘텐츠로 건너뛰기
DualShock 4 CHU-ZCT2U Disassembly
필요한 것
  1. DualShock 4 CHU-ZCT2U Disassembly, First Screws: 1 단계, 이미지 1/2 DualShock 4 CHU-ZCT2U Disassembly, First Screws: 1 단계, 이미지 2/2
    • All the screws are the same in the controller (Phillips's head).
  2. DualShock 4 CHU-ZCT2U Disassembly, Opening the Case: 2 단계, 이미지 1/1
    • Use a plastic spudger to open the case. Try not to scratch the plastic.
  3. DualShock 4 CHU-ZCT2U Disassembly, Separate the 2 halves: 3 단계, 이미지 1/2 DualShock 4 CHU-ZCT2U Disassembly, Separate the 2 halves: 3 단계, 이미지 2/2
    • Be careful opening the case because there is a ribbon cable holding the 3 halves together.
    • The plastic for the lightbar will look different from mine because it's fragile and it broke.
  4. DualShock 4 CHU-ZCT2U Disassembly, Battery: 4 단계, 이미지 1/2 DualShock 4 CHU-ZCT2U Disassembly, Battery: 4 단계, 이미지 2/2
    • Remove the battery and the screw underneath it.
  5. DualShock 4 CHU-ZCT2U Disassembly, Touchpad Ribbon Cable: 5 단계, 이미지 1/1
    • The ribbon cable slots through the rectangular hole in the plastic beneath.
  6. DualShock 4 CHU-ZCT2U Disassembly, Board: 6 단계, 이미지 1/1
    • Remove the board.
  7. DualShock 4 CHU-ZCT2U Disassembly, You Are Done!: 7 단계, 이미지 1/1
    • You're finished with your DualShock 4 dissasembly!
결론
To reassemble your device, follow these instructions in reverse order. If there are any issues, please tell me as this is my first guide
다른 8명이 해당 안내서를 완성하였습니다.
Mintyboi 88
회원 가입일: 04/17/20
316 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 69
30일 전: 306
전체 시간: 11,862
