이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Before attempting this guide, be sure you check out the device troubleshooting page to see if you can get your bluetooth working that way.
If not, we are going to go ahead and open the device as you will need to swap out your bluetooth module for a working one.
필요한 것
Lift up the handle to reveal the screws.
Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
Lift the plastic tab on the ribbon cable on the bluetooth module using the spudger.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Great fix it article. Thank you. I, too am wondering where to get the replacement Bluetooth module? Part number as well. Thank you very much.
