소개
If your device has completely stopped working you may need to swap out the motherboard inside your device. In this guide you will open up the boombox following the prerequisite disassembly guide and then replacing the motherboard with a working version.
필요한 것
Lift up the handle to reveal the screws.
Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
Gently pull the corresponding cables individually from the top of the motherboard to remove them.
For the next 3 steps, use the plastic prying tool if needed.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 3개
Where i can buy this motherboard?
Got it apart plug came back on staying on stand bye,?
My boombox is showing demo only cannot switch off and change mode. After 2 seconds.
