주요 콘텐츠로 건너뛰기
SONY ZS-BTG900 Remote Motherboard Replacement
필요한 것
  1. SONY ZS-BTG900 Remote Motherboard Replacement, Remote Motherboard: 1 단계, 이미지 1/2 SONY ZS-BTG900 Remote Motherboard Replacement, Remote Motherboard: 1 단계, 이미지 2/2
    • Flip the remote and remove the backing.
  2. SONY ZS-BTG900 Remote Motherboard Replacement: 2 단계, 이미지 1/2 SONY ZS-BTG900 Remote Motherboard Replacement: 2 단계, 이미지 2/2
    • Locate the screw behind the battery pack.
    • Use a Phillips size 1 screwdriver to remove the 5/16in screw located inside the battery port.
  3. SONY ZS-BTG900 Remote Motherboard Replacement: 3 단계, 이미지 1/2 SONY ZS-BTG900 Remote Motherboard Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool along the seam on the side of the remote until you hear a click. This means that the plastic tabs holding the remote together are coming loose.
    • Do this until the top half of the remote comes loose.
  4. SONY ZS-BTG900 Remote Motherboard Replacement: 4 단계, 이미지 1/2 SONY ZS-BTG900 Remote Motherboard Replacement: 4 단계, 이미지 2/2
    • Carefully remove the top to reveal the button covers and the remote control board.
  5. SONY ZS-BTG900 Remote Motherboard Replacement: 5 단계, 이미지 1/2 SONY ZS-BTG900 Remote Motherboard Replacement: 5 단계, 이미지 2/2
    • Lift the chip out of the plastic casing to replace it.
결론
Alfredo Rodriguez
회원 가입일: 04/11/16
972 평판
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 449
