이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the screw behind the battery pack.
Use a Phillips size 1 screwdriver to remove the 5/16in screw located inside the battery port.
Use the plastic opening tool along the seam on the side of the remote until you hear a click. This means that the plastic tabs holding the remote together are coming loose.
Do this until the top half of the remote comes loose.
Carefully remove the top to reveal the button covers and the remote control board.
