주요 콘텐츠로 건너뛰기
SONY ZS-BTG900 Speaker Replacement
필요한 것
  1. SONY ZS-BTG900 Speaker Replacement, SONY ZS-BTG900 Disassembly: 1 단계, 이미지 1/2 SONY ZS-BTG900 Speaker Replacement, SONY ZS-BTG900 Disassembly: 1 단계, 이미지 2/2
    • Lift up the handle to reveal the screws.
    • Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
  2. SONY ZS-BTG900 Speaker Replacement: 2 단계, 이미지 1/3 SONY ZS-BTG900 Speaker Replacement: 2 단계, 이미지 2/3 SONY ZS-BTG900 Speaker Replacement: 2 단계, 이미지 3/3
    • Flip your device over.
    • Use your Phillips #2 screwdriver to remove the six 3/4inch screws.
    • In removing the screws within the two holes on the back of the device, you may want to use your shaft extension to provide extra torque as they may be very tight.
  3. SONY ZS-BTG900 Speaker Replacement: 3 단계, 이미지 1/2 SONY ZS-BTG900 Speaker Replacement: 3 단계, 이미지 2/2
    • Flip your device back over to access the top of the device.
    • Use your plastic opening tool to pry up and remove the panel on the top, left hand side of the device.
    • This will reveal two additional screws.
  4. SONY ZS-BTG900 Speaker Replacement: 4 단계, 이미지 1/1
    • Use your Phillips #2 screwdriver to remove the two 1/2 inch screws underneath the now-removed panels.
  5. SONY ZS-BTG900 Speaker Replacement: 5 단계, 이미지 1/2 SONY ZS-BTG900 Speaker Replacement: 5 단계, 이미지 2/2
    • Lift off the top, beginning from the back of the device.
    • Take care when lifting the top portion as there are many wires connected to the inside of the device and you do not want to disconnect these just yet.
  6. SONY ZS-BTG900 Speaker Replacement: 6 단계, 이미지 1/2 SONY ZS-BTG900 Speaker Replacement: 6 단계, 이미지 2/2
    • Disconnect the CD drive ribbon cable from the top of the device.
  7. SONY ZS-BTG900 Speaker Replacement: 7 단계, 이미지 1/2 SONY ZS-BTG900 Speaker Replacement: 7 단계, 이미지 2/2
    • Disconnect the antenna cables.
  8. SONY ZS-BTG900 Speaker Replacement: 8 단계, 이미지 1/3 SONY ZS-BTG900 Speaker Replacement: 8 단계, 이미지 2/3 SONY ZS-BTG900 Speaker Replacement: 8 단계, 이미지 3/3
    • Disconnect the remaining cables from the motherboard.
  9. SONY ZS-BTG900 Speaker Replacement: 9 단계, 이미지 1/2 SONY ZS-BTG900 Speaker Replacement: 9 단계, 이미지 2/2
    • Once you have removed the top, we will begin removing the front of the device.
    • Begin by disconnecting the 6 cables that lead from the front of the device to the motherboard.
  10. SONY ZS-BTG900 Speaker Replacement: 10 단계, 이미지 1/1
    • Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
    • Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
    • Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
  11. SONY ZS-BTG900 Speaker Replacement: 11 단계, 이미지 1/2 SONY ZS-BTG900 Speaker Replacement: 11 단계, 이미지 2/2
    • Firmly pull off the front of device.
    • There will be a small amount of black glue. You can simply ignore this, and continue to pull, or use a sharp edge to cut the glue once you've revealed it.
  12. SONY ZS-BTG900 Speaker Replacement, Speaker: 12 단계, 이미지 1/1
    • This guide will be for the two speakers seen on the left and right of the image.
  13. SONY ZS-BTG900 Speaker Replacement: 13 단계, 이미지 1/3 SONY ZS-BTG900 Speaker Replacement: 13 단계, 이미지 2/3 SONY ZS-BTG900 Speaker Replacement: 13 단계, 이미지 3/3
    • Begin by desoldering the connector wires off the metal plate at the bottom of the speaker.
    • Be sure to note where each wire will be resoldered when you have your new speaker in place.
  14. SONY ZS-BTG900 Speaker Replacement: 14 단계, 이미지 1/1
    • Use a Phillips #2 screwdriver to remove the 1/2 inch screws.
  15. SONY ZS-BTG900 Speaker Replacement: 15 단계, 이미지 1/2 SONY ZS-BTG900 Speaker Replacement: 15 단계, 이미지 2/2
    • With the wires and screws removed, firmly grab the top of the speaker.
    • Pull up and away to remove the whole speaker.
결론
Alfredo Rodriguez
회원 가입일: 04/11/16
972 평판
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 827
