주요 콘텐츠로 건너뛰기
SR 306-12951100 Acoustic Guitar Tuning Keys Replacement
필요한 것
  1. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement, Tuning Keys: 1 단계, 이미지 3개 중 1개 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement, Tuning Keys: 1 단계, 이미지 3개 중 2개 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement, Tuning Keys: 1 단계, 이미지 3개 중 3개
    • Remove the four outer screws.
    • Then remove the four inner screws.
    • The screws are located on the back of the guitar head.
  2. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 2 단계, 이미지 2개 중 1개 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 2 단계, 이미지 2개 중 2개
    • Slide all of the collars off of the old tuning keys.
    • The collars are found on the tuning key pegs on the front head of the guitar. One of the collars is indicated in the first picture.
    • Some of the collars may be difficult to remove. Apply gentle pressure until they pop off.
  3. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 3 단계, 이미지 3개 중 1개 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 3 단계, 이미지 3개 중 2개 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the old tuning keys by sliding them out of the holes.
    • It helps to put the guitar on its side and hold the head of the guitar from the front and push the old tuning keys out the back.
  4. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 4 단계, 이미지 2개 중 1개 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 4 단계, 이미지 2개 중 2개
    • Clean the guitar head and tuning key holes using a microfiber cloth to ensure that the new tuning keys will fit properly.
    • This step may require more or less effort depending on how much epoxy was used to hold the old tuning keys in place.
  5. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 5 단계, 이미지 3개 중 1개 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 5 단계, 이미지 3개 중 2개 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 5 단계, 이미지 3개 중 3개
    • Insert one of the new tuning key racks into the appropriate tuning key holes.
    • Both of the new tuning key pieces are identical, so either plate can be used.
    • The plate should have an overall length of 102 mm. The center to center distance between posts should be 35 mm.
  6. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 6 단계, 이미지 3개 중 1개 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 6 단계, 이미지 3개 중 2개 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 6 단계, 이미지 3개 중 3개
    • Insert the second tuning key rack into the appropriate tuning key holes.
  7. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 7 단계, 이미지 3개 중 1개 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 7 단계, 이미지 3개 중 2개 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 7 단계, 이미지 3개 중 3개
    • Begin installing the four outer screws.
    • Then install the four inner screws.
    • The dimensions of the screws that come with the kit are 31 mm x 35 mm x 27 mm.
    • Do not tighten the screws until all of them are in place. Once all eight screws are in, go back and tighten each one. This is done so that the new tuning keys can be properly aligned.
  8. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 8 단계, 이미지 2개 중 1개 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 8 단계, 이미지 2개 중 2개
    • The tuning keys are now properly installed.
    • Install new guitar strings by following this video (start at 1 min 20 sec.) and this guide.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Michael Biancardi
회원 가입일: 01/16/20
213 평판
안내서 1개를 작성함
2가이드 댓글
I literally just bought this exact guitar at goodwill!
Hugh Bourns - 답글
Hi Michael,
I just bought this exact guitar at an estate sale this past weekend I bought it for my granddaughter to learn how to play the neck has a little bow in it and I was wondering if you knew what size the adjustment screw is and what type head it is.
Thanks!
Dennis
D Carter - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 965
