주요 콘텐츠로 건너뛰기
SR405QM Battery Replacement
필요한 것
  1. SR405QM Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Gently place the instrument upside-down on a soft surface.
    • Locate the battery cavity cap and screws.
  2. SR405QM Battery Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #2 head screwdriver to unscrew both screws. Two #1 1mm long screws.
  3. SR405QM Battery Replacement: 3 단계, 이미지 1/2 SR405QM Battery Replacement: 3 단계, 이미지 2/2
    • Remove the cap by lifting upwards to reveal the battery.
  4. SR405QM Battery Replacement: 4 단계, 이미지 1/3 SR405QM Battery Replacement: 4 단계, 이미지 2/3 SR405QM Battery Replacement: 4 단계, 이미지 3/3
    • Gently lift the battery from the cavity.
    • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
결론
To reassemble your device, follow these instructions in reverse order with a fresh battery.
다른 2명이 해당 안내서를 완성하였습니다.
Chris Pittner
회원 가입일: 01/11/13
220 평판
안내서 7개 작성하였습니다
Cal Poly, Team 5-18, Forte Winter 2013 Cal Poly, Team 5-18, Forte Winter 2013 회원
CPSU-FORTE-W13S5G18
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,149
