주요 콘텐츠로 건너뛰기
SSD M.2 Drive Replacement
필요한 것
  1. SSD M.2 Drive Replacement, Unplug all cables: 1 단계, 이미지 2개 중 1개 SSD M.2 Drive Replacement, Unplug all cables: 1 단계, 이미지 2개 중 2개
    • Turn off your computer if it is on.
    • Unplug all cables at the back and the front of your computer.
    • Make sure to turn off the power supply by putting the switch at the "O" position.
  2. SSD M.2 Drive Replacement, Remove the side panel: 2 단계, 이미지 3개 중 1개 SSD M.2 Drive Replacement, Remove the side panel: 2 단계, 이미지 3개 중 2개 SSD M.2 Drive Replacement, Remove the side panel: 2 단계, 이미지 3개 중 3개
    • Remove the side panel to gain access to the inside of your computer. To access the side panel, (except as described below) you need to remove the screws on the rear of the case, then slide the case to remove it.
    • In my case, with a DarkWitcher case from Empire Gaming, I need to unscrew 4 screws to lift and remove the side panel.
    • Locate the M.2 slot on your motherboard. If you don't see it, it may be hidden under the graphics card, you can check in the motherboard's manuel to find where it is.
  3. SSD M.2 Drive Replacement, Unplug the GPU power cable: 4 단계, 이미지 3개 중 1개 SSD M.2 Drive Replacement, Unplug the GPU power cable: 4 단계, 이미지 3개 중 2개 SSD M.2 Drive Replacement, Unplug the GPU power cable: 4 단계, 이미지 3개 중 3개
    • If the M.2 slot is accessible without having to remove the graphics card, you can proceed immediately to step 6.
    • Otherwise, unplug the power cable from the graphics card by levering the clip on the connector and remove it.
  4. SSD M.2 Drive Replacement, Remove the GPU: 5 단계, 이미지 3개 중 1개 SSD M.2 Drive Replacement, Remove the GPU: 5 단계, 이미지 3개 중 2개 SSD M.2 Drive Replacement, Remove the GPU: 5 단계, 이미지 3개 중 3개
    • Remove the screws holding the graphics card in place.
    • Push on the clip at the right of the GPU slot.
    • Remove the graphics card by gently lifting it out. You can use a plastic spatula to do this.
  5. SSD M.2 Drive Replacement, Remove the heat sink: 6 단계, 이미지 3개 중 1개 SSD M.2 Drive Replacement, Remove the heat sink: 6 단계, 이미지 3개 중 2개 SSD M.2 Drive Replacement, Remove the heat sink: 6 단계, 이미지 3개 중 3개
    • If your motherboard has no heat sink on you SSD, you can go the next step.
    • If not, remove the screw holding the heatsink in place.
    • Then remove the heat sink by lifting it up.
    • The thermal pad glued to the heatsink may stick slightly to the SSD, so don't be afraid to lift it.
    • Place the heat sink on the opposite side to the one to which the thermal pad is glued.
  6. SSD M.2 Drive Replacement, Remove the SSD Drive: 7 단계, 이미지 3개 중 1개 SSD M.2 Drive Replacement, Remove the SSD Drive: 7 단계, 이미지 3개 중 2개 SSD M.2 Drive Replacement, Remove the SSD Drive: 7 단계, 이미지 3개 중 3개
    • Remove the screw securing the disk in place.
    • Once the screw has been removed, the drive will lift itself.
    • Pull the drive to the left to take it out of the slot.
  7. SSD M.2 Drive Replacement, Insert the new drive: 8 단계, 이미지 2개 중 1개 SSD M.2 Drive Replacement, Insert the new drive: 8 단계, 이미지 2개 중 2개
    • Align the notch on the slot with the notch on the drive.
    • Insert the new drive in the slot.
  8. SSD M.2 Drive Replacement, Screw the screw: 9 단계, 이미지 2개 중 1개 SSD M.2 Drive Replacement, Screw the screw: 9 단계, 이미지 2개 중 2개
    • Press slightly on the disc to engage. Align the semi-circle at the end of the disc with the hole in the screw.
    • Screw the screw.
결론
To reassemble you device, follow the instructions in reverse order beginning by the sixth step.
다른 6명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Gaëtan Suss
회원 가입일: 12/01/22
2,209 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 121
지난 30일: 580
전체 시간: 16,992
