주요 콘텐츠로 건너뛰기
STANDARD C520 C528 Repairing setting of TX-audio and 1750-tone Replacement
필요한 것
  1. STANDARD C520 C528 Repairing setting of TX-audio and 1750-tone Replacement, Replacing capacitors and cleanup: 1 단계, 이미지 1개 중 1개
    • Cover the plastic-front against scratches and daamages.
  2. STANDARD C520 C528 Repairing setting of TX-audio and 1750-tone Replacement: 2 단계, 이미지 1개 중 1개
    • Loose the screws on the back and on the bottom
  3. STANDARD C520 C528 Repairing setting of TX-audio and 1750-tone Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the screws, marked red. Locate the old capacitors, marked yellow. And locate the old battery, marked green.
  4. STANDARD C520 C528 Repairing setting of TX-audio and 1750-tone Replacement: 4 단계, 이미지 1개 중 1개
    • Replace the old caps. At best exchange to tantalium. The three caps on the left uper side and the above the CPU must be replaced against 220µF 6V. Replace the battery It is a wired CR2016.
  5. STANDARD C520 C528 Repairing setting of TX-audio and 1750-tone Replacement: 5 단계, 이미지 1개 중 1개
    • Next lets have a look on the RF-unit. Loose the screws and desolder the antenna connector. Unmount the board. Then locate and replace the caps.
  6. STANDARD C520 C528 Repairing setting of TX-audio and 1750-tone Replacement: 6 단계, 이미지 1개 중 1개
    • Remember to replace the cap bottom left as well. The marked trimmer is for freqeuncy-alignment
  7. STANDARD C520 C528 Repairing setting of TX-audio and 1750-tone Replacement, Repairing setting of TX-audio and 1750-tone: 7 단계, 이미지 1개 중 1개
    • When you have problems setting deviation of audio and tone, then desolder the trimmer R392, R395 and R397. Clean up the board in this area and reinstall the trimmer. Pleace test them and replace the trimmer agains new ones if values do not fit.
결론
For dis- and reassembling pleace watch the repair-guide for replacing capacitors on STANDARD C-528 here on ifixit.com
작성자
2다른 기여자 명과 함께
ELKOBA
회원 가입일: 06/24/23
312 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 203
