주요 콘텐츠로 건너뛰기
SVP 5800 Back Casing Replacement
필요한 것
  1. SVP 5800 Back Casing Replacement, Strap Hook: 1 단계, 이미지 3개 중 1개 SVP 5800 Back Casing Replacement, Strap Hook: 1 단계, 이미지 3개 중 2개 SVP 5800 Back Casing Replacement, Strap Hook: 1 단계, 이미지 3개 중 3개
    • Locate the two 3.5 mm screws on the side of the device.
    • Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
  2. SVP 5800 Back Casing Replacement, Front Casing: 2 단계, 이미지 2개 중 1개 SVP 5800 Back Casing Replacement, Front Casing: 2 단계, 이미지 2개 중 2개
    • Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
    • Refer to the prerequisite guide on removing the strap hook for instructions.
    • Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
  3. SVP 5800 Back Casing Replacement: 3 단계, 이미지 2개 중 1개 SVP 5800 Back Casing Replacement: 3 단계, 이미지 2개 중 2개
    • Place the plastic opening tool on the crack between the front and back casings.
    • Apply pressure by pulling down on the plastic opening tool to pry the case apart.
  4. SVP 5800 Back Casing Replacement: 4 단계, 이미지 2개 중 1개 SVP 5800 Back Casing Replacement: 4 단계, 이미지 2개 중 2개
    • Wedge your fingers in the opening and slowly pull the front casing away from the bottom casing until it complete separates from the device.
    • Using too much force in this step can damage your device.
  5. SVP 5800 Back Casing Replacement, Top button Compartment: 5 단계, 이미지 3개 중 1개 SVP 5800 Back Casing Replacement, Top button Compartment: 5 단계, 이미지 3개 중 2개 SVP 5800 Back Casing Replacement, Top button Compartment: 5 단계, 이미지 3개 중 3개
    • Insert the flat end of wide metal spudger into the seam of the plastic buffer surrounding the buttons and pry it open.
  6. SVP 5800 Back Casing Replacement: 6 단계, 이미지 3개 중 1개 SVP 5800 Back Casing Replacement: 6 단계, 이미지 3개 중 2개 SVP 5800 Back Casing Replacement: 6 단계, 이미지 3개 중 3개
    • Use A #00 Phillips head screwdriver and turn counterclockwise to remove the four indicated screws.
    • Set the screws aside.
  7. SVP 5800 Back Casing Replacement: 7 단계, 이미지 2개 중 1개 SVP 5800 Back Casing Replacement: 7 단계, 이미지 2개 중 2개
    • Apply pressure and turn counterclockwise to remove the indicated 2.5 mm screw.
  8. SVP 5800 Back Casing Replacement, Back Casing: 8 단계, 이미지 2개 중 1개 SVP 5800 Back Casing Replacement, Back Casing: 8 단계, 이미지 2개 중 2개
    • Locate the 2 mm screw that is next to the battery compartment.
    • Using the PH J000 phillips head screwdriver, apply pressure to the screw head and turn in a counter clockwise motion until the screw is loose.
    • You do not have to completely remove the 2 mm screw. To prevent losing the screw, you may leave it loosely in its place.
  9. SVP 5800 Back Casing Replacement: 9 단계, 이미지 3개 중 1개 SVP 5800 Back Casing Replacement: 9 단계, 이미지 3개 중 2개 SVP 5800 Back Casing Replacement: 9 단계, 이미지 3개 중 3개
    • Slide the flat edge of the plastic opening tool between the inner casing and the back outer casing.
    • Push up on the plastic opening tool so that the back casing starts to lift from the inner casing.
    • Lifting the casing too far may result in damage. Lift the casing slowly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cheyenne Heinen
회원 가입일: 03/07/16
358 평판
안내서 3개를 작성함
Marist, Team 1-3, Laflen Spring 2016 Marist, Team 1-3, Laflen Spring 2016 회원
MARS-LAFLEN-S16S1G3
2 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 554
