주요 콘텐츠로 건너뛰기
SVP 5800 Front Casing Replacement
필요한 것
  1. SVP 5800 Front Casing Replacement, Strap Hook: 1 단계, 이미지 3개 중 1개 SVP 5800 Front Casing Replacement, Strap Hook: 1 단계, 이미지 3개 중 2개 SVP 5800 Front Casing Replacement, Strap Hook: 1 단계, 이미지 3개 중 3개
    • Locate the two 3.5 mm screws on the side of the device.
    • Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
  2. SVP 5800 Front Casing Replacement, Front Casing: 2 단계, 이미지 2개 중 1개 SVP 5800 Front Casing Replacement, Front Casing: 2 단계, 이미지 2개 중 2개
    • Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
    • Refer to the prerequisite guide on removing the strap hook for instructions.
    • Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
  3. SVP 5800 Front Casing Replacement: 3 단계, 이미지 2개 중 1개 SVP 5800 Front Casing Replacement: 3 단계, 이미지 2개 중 2개
    • Place the plastic opening tool on the crack between the front and back casings.
    • Apply pressure by pulling down on the plastic opening tool to pry the case apart.
  4. SVP 5800 Front Casing Replacement: 4 단계, 이미지 2개 중 1개 SVP 5800 Front Casing Replacement: 4 단계, 이미지 2개 중 2개
    • Wedge your fingers in the opening and slowly pull the front casing away from the bottom casing until it complete separates from the device.
    • Using too much force in this step can damage your device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Cheyenne Heinen
회원 가입일: 03/07/16
358 평판
안내서 3개를 작성함
Marist, Team 1-3, Laflen Spring 2016 Marist, Team 1-3, Laflen Spring 2016 회원
MARS-LAFLEN-S16S1G3
2 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 475
