주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
When the body on the steam valve is cracked, it has to be replaced. This will show how to do that.
도구
지정된 도구가 없습니다.
부품
  1. Never forget: Pull the plug out!
    • Never forget: Pull the plug out!
    • Remove all attachments such as drawers, water tank, brewing unit.
    • Carefully pull the steam button out. If it is too tight, first loosen the cover (steps 2 to 4), lift slightly and then push the ratchet nose with a small screwdriver.
  2. The bean container is fixed with two Phillipps screws. Unscrew those.
    • The bean container is fixed with two Phillipps screws. Unscrew those.
    • The adjusters of the grinder and the quantity of coffee (if present) can remain.
    • Lift the bean container up und remove it from the device.
  3. Remove the single T10 Torx screw on the rear edge of the top cover under the water reservoir. Remove the single  Phillipps screw on the rear edge of the top cover under the container of the coffee beans. There are two Phillipps screws on the frontal unterside edge of the top cover. Turn them out.
    • Remove the single T10 Torx screw on the rear edge of the top cover under the water reservoir.
    • Remove the single Phillipps screw on the rear edge of the top cover under the container of the coffee beans.
    • There are two Phillipps screws on the frontal unterside edge of the top cover. Turn them out.
  4. Now the cover can be lifted off. Pull backwards, then diagonally forward. Remove the silicone hose from the water tank.
    • Now the cover can be lifted off. Pull backwards, then diagonally forward. Remove the silicone hose from the water tank.
  5. The steam valve is located on the top right of the machine. If it has cracks, water will drip out of the valve body.
    • The steam valve is located on the top right of the machine. If it has cracks, water will drip out of the valve body.
  6. Remove the clamp securing the pressure hose to the valve body.
    • Remove the clamp securing the pressure hose to the valve body.
    • Disconnect the pressure hose from the valve body.
    • The end of the pressure hose is sealed with two O-rings. Those will either stick on the valve body or on the pressure hose. Whenever possible replace them when re-assembling.
  7. The steam valve must be pushed to the right, but a microswitch will still be in the way.
    • The steam valve must be pushed to the right, but a microswitch will still be in the way.
    • The microswitch is mounted on the underside of the gray frame with two notches. Insert a small screwdriver into the gap under the gray frame. Gently push the two notches one after the other and lift the microswitch upwards. The cables can stay connected.
  8. The steam valve is still secured with a catch. Lift the catch with a flat-head screwdriver and slide the complete valve to the right.
    • The steam valve is still secured with a catch. Lift the catch with a flat-head screwdriver and slide the complete valve to the right.
    • To remove the valve it can now be pulled out of the gray frame in a forward direction.
결론
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
VauWeh
회원 가입일: 2015년 10월 19일
103,280 평판
안내서 140개 작성하였습니다
Share & Repair Share & Repair 회원
Community
9 회원들
안내서 227개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 50
전체 시간: 902
