주요 콘텐츠로 건너뛰기
Saitek Cyborg V3 Disassembly
필요한 것
  1. Saitek Cyborg V3 Disassembly, Open the mouse: 1 단계, 이미지 3개 중 1개 Saitek Cyborg V3 Disassembly, Open the mouse: 1 단계, 이미지 3개 중 2개 Saitek Cyborg V3 Disassembly, Open the mouse: 1 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screw driver to open the back cover.
    • Gently push away the bottom part on the opposite side to the cable.
    • As in the "push away" step, there should be about 30° between the bottom and top part. Push on the bottom part up, so the fit is tight around the cable. Slowly move parts together to reduce the angle.
  2. Saitek Cyborg V3 Disassembly, Dismantle the big top cover: 2 단계, 이미지 2개 중 1개 Saitek Cyborg V3 Disassembly, Dismantle the big top cover: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to unscrew the big top mouse part with both buttons.
    • Use whatever you find appropriate (I used a screwdriver) to gently push the clips (yellow) and next push to one of the circles (red) to separate the big top part.
  3. Saitek Cyborg V3 Disassembly, Dismantle cover with DPI button: 3 단계, 이미지 2개 중 1개 Saitek Cyborg V3 Disassembly, Dismantle cover with DPI button: 3 단계, 이미지 2개 중 2개
    • Use whatever you find appropriate (I used a screwdriver) to gently push the clips (red) and use whatever you find appropriate (I used a thin screwdriver bit) to push the pin (yellow).
    • Now if you very gently push to the bottom part of the cover, it should pop out on itself.
  4. Saitek Cyborg V3 Disassembly, Separate the electronics: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #00 bit to unscrew two screws on the motherboard.
    • Carefully lift the whole motherboard out of the mouse.
결론
작성자
1다른 기여자 명과 함께
Vaclav Sobotka
회원 가입일: 01/24/16
1 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 442
