주요 콘텐츠로 건너뛰기
Saitek X52 Pro Disassembly
필요한 것
  1. Saitek X52 Pro Disassembly, Get your tools: 1 단계, 이미지 1/1
  2. Saitek X52 Pro Disassembly, Open the Joystick - Unscrewing: 2 단계, 이미지 1/3 Saitek X52 Pro Disassembly, Open the Joystick - Unscrewing: 2 단계, 이미지 2/3 Saitek X52 Pro Disassembly, Open the Joystick - Unscrewing: 2 단계, 이미지 3/3
    • Please take a moment and note how your joystick is assembled and all the parts that can be dettached. I recommend taking a few photos before dismantling it.
    • With the Phillips screwdrive unscrew the #1 to #4 screws in Fig. 1.
    • Using the Torx T10 head, unscrew the #5 (Fig. 1), #6, #7 and #8 screws (Fig. 2)
    • Screws 5 & 6 have a larger thread pace than 7 & 8, although the heads are the same. So please take care when you screw them back on (Fig. 3).
    • Using your hand, unscrew #9 (Fig. 2). Please note that you cannot completely remove this screw, but you don't need to do this anyway.
  3. Saitek X52 Pro Disassembly, Open the Joystick - Removing the bracket and the cover: 3 단계, 이미지 1/2 Saitek X52 Pro Disassembly, Open the Joystick - Removing the bracket and the cover: 3 단계, 이미지 2/2
    • Carefully remove the plastic bracket and the support holding the "Pinkie trigger" by pushing it towards the trigger (Fig. 4).
    • DO NOT force its removal, or you can break it.
    • Be careful not to break the Pinkie trigger wire!
    • Remove the stick cover that will expose the contacts and wiring (Fig. 5)
  4. Saitek X52 Pro Disassembly, Fixing it: 4 단계, 이미지 1/1
    • Note the small metal plate.
    • Bend it just a little from the middle so that pushing the trigger actually pushes the small blue switch inside the stick.
    • Test the trigger before putting back the plastic cover
    • Remember when screwing the screws that 5&6 go to the bottom sides and 7&8 go at the top.
    • Note: Inside the trigger there is two screws which can be used instead of either extend or retract the pin that presses the metal plate. Try adjusting this first.
결론
다른 21명이 해당 안내서를 완성하였습니다.
Cri Cri
회원 가입일: 01/22/14
611 평판
안내서 1개 작성함
댓글 21개
Amazing this is what I was exactly looking for!! My trigger stopped work but only heard a single click. Once i opened it up one of the contacts was stuck down. A little adjustment and once again it was working. Getting the hand guard off was very tricky. I did damage the cable guide thing for the pinky switch but it still works. Thank you soo much!!!
Mathew Smith - 답글
Glad it helped you! It appears to be a common fault with this joystick.
Sorry to hear about the damaging cable, but I imagine is fixable if it breaks over time.
Cri Cri - 답글
Fixed it!! Thank you so much for this guide! I ended up over bending it and then tried to straighten it out again and then it shot off somewhere, but luckily the piece fits back in and then i tweaked it until it worked! -Nate
nenglish87 - 답글
This helped a great deal! The Thumb POV had a screw that dropped out and prevented it from going left. By using this I found out why it wasn't working by disassembling it and solved my problem. Thanks!
Arthur Moyer - 답글
I was kind of hoping this would be a full Disassembly, as i have much more intricate problem with mine.
Paul - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 35
30일 전: 192
전체 시간: 26,589
