주요 콘텐츠로 건너뛰기
Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement
필요한 것
  1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: 1 단계, 이미지 1/2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: 1 단계, 이미지 2/2
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 2 단계, 이미지 1/3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 2 단계, 이미지 2/3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 2 단계, 이미지 3/3
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 3 단계, 이미지 1/3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 3 단계, 이미지 2/3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 3 단계, 이미지 3/3
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: 4 단계, 이미지 1/2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: 4 단계, 이미지 2/2
    • Remove the green protective tape from the three ZIF connectors on the motherboard.
    • Pull the ribbon cables out of their sockets.
  5. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 5 단계, 이미지 1/2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 5 단계, 이미지 2/2
    • Remove the six 4mm Phillips #000 screws from the motherboard.
    • Remove the motherboard.
  6. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 6 단계, 이미지 1/2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 6 단계, 이미지 2/2
    • Insert a plastic opening tool between the screen and bezel.
    • Slide the plastic opening tool around the perimeter while applying a prying motion.
    • Remove the screen from the display.
    • Applying heat may be needed to loosed the glue.
  7. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 7 단계, 이미지 1/2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 7 단계, 이미지 2/2
    • Locate the Home button on the front of the panel and carefully lift the gold ribbon surrounding it from RIGHT to LEFT.
  8. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 8 단계, 이미지 1/1
    • Using your Phillips #000 screwdriver Remove the two 4mm Phillips #000 screws from the home button.
  9. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 9 단계, 이미지 1/1
    • Remove the home button by sliding it to the left or right while pulling up.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Guneet Bawa
회원 가입일: 04/12/18
688 평판
안내서 4개 작성하였습니다
UW Tacoma, Team S1-G5, Liner Spring 2018 UW Tacoma, Team S1-G5, Liner Spring 2018 회원
UWT-LINER-S18S1G5
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 17
전체 시간: 2,003
