주요 콘텐츠로 건너뛰기
Samsung SmartCam HD Pro Casing Replacement
필요한 것
  1. Samsung  SmartCam HD Pro Casing Replacement, Casing: 1 단계, 이미지 1/1
    • Locate a small opening around the front panel of the camera.
  2. Samsung  SmartCam HD Pro Casing Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool, apply pressure to various points around the camera to pry open the front panel.
  3. Samsung  SmartCam HD Pro Casing Replacement: 3 단계, 이미지 1/1
    • Remove both of the connecting wires from the motherboard.
    • Be careful to not bend headers or damage the wires.
  4. Samsung  SmartCam HD Pro Casing Replacement: 4 단계, 이미지 1/1
    • Apply a plastic opening tool to the gray plastic band around the case of the camera. Insert the edge of the spudger between the case of the camera and the gray plastic band.
  5. Samsung  SmartCam HD Pro Casing Replacement: 5 단계, 이미지 1/1
    • Apply pressure with the plastic opening tool to various areas of the gray plastic band to pry it from the white plastic back of the case.
결론
AllisonBridges
회원 가입일: 01/18/17
501 평판
안내서 5개 작성하였습니다
Arkansas State University, Team 1-1, Chamberlain Spring 2017 Arkansas State University, Team 1-1, Chamberlain Spring 2017 회원
ARSU-CHAMBERLAIN-S17S1G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 670
