이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Insert the heavy duty spudger in between the monitors back panel and its frame.
Use the heavy duty spudger to pry open the back panel.
Remove the navigation button connector by pulling while holding down its thumb tab.
Remove the screen connector by gripping its sides and gently pulling while wiggling back and forth.
For the ribbon cable, Lift the tab from the side facing the inside of the mother board with your fingernail or a spudger.
Remove the cable by pulling while lifting slightly.
Remove each of the 5mm length screws attaching the motherboard to the body of the monitor using a #1 Phillips head screwdriver.
Using both hands, lift the board off of the monitor body by the motherboards base.
다른 한 분이 해당 안내서를 완성하였습니다.
