주요 콘텐츠로 건너뛰기
Samsung 500C ChromeBook Battery Replacement
필요한 것
  1. Samsung 500C ChromeBook Battery Replacement, Battery: 1 단계, 이미지 1/2 Samsung 500C ChromeBook Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Use the spudger to remove the four rubber feet on the bottom panel.
    • Remove the seven Philips #1 screws.
  2. Samsung 500C ChromeBook Battery Replacement: 2 단계, 이미지 1/3 Samsung 500C ChromeBook Battery Replacement: 2 단계, 이미지 2/3 Samsung 500C ChromeBook Battery Replacement: 2 단계, 이미지 3/3
    • Remove the seven Phillips #1 screws holding the battery in place.
    • Detach the battery connector by pulling the connector towards the battery.
    • Pull from the plastic connector, do not pull from the wires.
    • Remove the battery.
    • When reinserting the battery, it is easier to insert from the long end first before lowering the rest of the battery into place.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Garrett Kissinger
회원 가입일: 02/24/14
704 평판
안내서 5개 작성하였습니다
Michigan Tech, Team 1-2, Lauer Spring 2014 Michigan Tech, Team 1-2, Lauer Spring 2014 회원
MTU-LAUER-S14S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 3개
Samsung 500C ChromeBook Battery where to buy?
Uzi Naveh - 답글
I keep typing charger and all you is replacing the battery. Without a charger I can't know if the battery is bad. Can you help or not???
Carol South - 답글
Don't show my NAME
Carol South - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 3,187
