주요 콘텐츠로 건너뛰기
Samsung 500C ChromeBook CPU Fan Replacement
필요한 것
  1. Samsung 500C ChromeBook CPU Fan Replacement, CPU Fan: 1 단계, 이미지 1/2 Samsung 500C ChromeBook CPU Fan Replacement, CPU Fan: 1 단계, 이미지 2/2
    • Remove the seven screws from the back panel of the device using a Phillips #0 screwdriver.
    • Four of the screws are under the rubber feet so they will need to be removed with a spudger.
    • Remove the back panel from the laptop.
  2. Samsung 500C ChromeBook CPU Fan Replacement: 2 단계, 이미지 1/3 Samsung 500C ChromeBook CPU Fan Replacement: 2 단계, 이미지 2/3 Samsung 500C ChromeBook CPU Fan Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the two screws holding in the CPU fan.
    • Lift the CPU fan.
    • You might encounter some slight resistance from the thermal paste on the heatsink.
    • Detach the cord attached to the fan and attach it to the new CPU fan.
    • Insert the new fan and reassemble the device.
결론
Enjoy your cool laptop!
다른 2명이 해당 안내서를 완성하였습니다.
Garrett Kissinger
회원 가입일: 02/24/14
704 평판
안내서 5개 작성하였습니다
Michigan Tech, Team 1-2, Lauer Spring 2014 Michigan Tech, Team 1-2, Lauer Spring 2014 회원
MTU-LAUER-S14S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
la pantalla no enciende, el ventilador arranca pero se apaga, el boton de poder da señal de encendido pero no enciende la pantalla
sergio rafael aguilar cantoral - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 983
