부품
No parts specified.
  1. Remove the back panel of the device by taking out the seven screws on the back panel of the device. Four of the screws are under the rubber feet so they will need to be removed.  To remove the feet, pry them off with the spudger.
    • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
    • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
  2. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  3. Remove the two screws holding in the CPU fan.  They can be shown circled in picture two. Lift the CPU fan.  You might encounter some resistance from the thermal paste on the heatsink. Detach the cord attached to the fan and attach it to the new CPU fan.  The point where the cord connects to the board is highlighted in picture three.  Insert the new fan and reassemble the device.
    • Remove the two screws holding in the CPU fan. They can be shown circled in picture two.
    • Lift the CPU fan. You might encounter some resistance from the thermal paste on the heatsink.
    • Detach the cord attached to the fan and attach it to the new CPU fan. The point where the cord connects to the board is highlighted in picture three. Insert the new fan and reassemble the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Garrett Kissinger
회원 가입일: 2014년 02월 24일
692 평판
안내서 5개 작성하였습니다
Michigan Tech, Team 1-2, Lauer Spring 2014 Michigan Tech, Team 1-2, Lauer Spring 2014 회원
MTU-LAUER-S14S1G2
3 회원들
안내서 5개 작성하였습니다
la pantalla no enciende, el ventilador arranca pero se apaga, el boton de poder da señal de encendido pero no enciende la pantalla
sergio rafael aguilar cantoral - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 732
