주요 콘텐츠로 건너뛰기
Samsung 500C ChromeBook Internal Speakers Replacement
필요한 것
  1. Samsung 500C ChromeBook Internal Speakers Replacement, Internal Speakers: 1 단계, 이미지 1/2 Samsung 500C ChromeBook Internal Speakers Replacement, Internal Speakers: 1 단계, 이미지 2/2
    • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
    • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
  2. Samsung 500C ChromeBook Internal Speakers Replacement: 2 단계, 이미지 1/2 Samsung 500C ChromeBook Internal Speakers Replacement: 2 단계, 이미지 2/2
    • Note: The Speaker is held in with an adhesive back so some force will be needed to remove it.
    • Remove the speaker using a spudger and detach the cord connected to it from the laptop. The speaker location is seen highlighted in picture 1.
    • Attach the cord of your replacement speaker and reassemble the device.
결론
Garrett Kissinger
회원 가입일: 02/24/14
704 평판
안내서 5개 작성하였습니다
Michigan Tech, Team 1-2, Lauer Spring 2014 Michigan Tech, Team 1-2, Lauer Spring 2014 회원
MTU-LAUER-S14S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 961
