주요 콘텐츠로 건너뛰기
Samsung 500C ChromeBook WIreless Card Replacement
필요한 것
  1. Samsung 500C ChromeBook WIreless Card Replacement, Wireless Card: 1 단계, 이미지 1/2 Samsung 500C ChromeBook WIreless Card Replacement, Wireless Card: 1 단계, 이미지 2/2
    • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
    • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
  2. Samsung 500C ChromeBook WIreless Card Replacement: 2 단계, 이미지 1/3 Samsung 500C ChromeBook WIreless Card Replacement: 2 단계, 이미지 2/3 Samsung 500C ChromeBook WIreless Card Replacement: 2 단계, 이미지 3/3
    • Locate the wireless card. It is shown highlighted in picture one.
    • Detach the black and white cords connected to the wireless card and unscrew the screw holding in the card. They are shown highlighted in picture two.
    • Pull the card out of its slot and insert the new card. Reattach the wires and reassemble the device. Note: the white wire connects to the terminal closer to the screw and the black to the other terminal.
결론
Garrett Kissinger
회원 가입일: 02/24/14
704 평판
안내서 5개 작성하였습니다
Michigan Tech, Team 1-2, Lauer Spring 2014 Michigan Tech, Team 1-2, Lauer Spring 2014 회원
MTU-LAUER-S14S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 1,869
