주요 콘텐츠로 건너뛰기
Samsung ATIV Book 4 Screen Replacement
필요한 것
  1. Samsung ATIV Book 4 Screen Replacement, Screen: 1 단계, 이미지 1/2 Samsung ATIV Book 4 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Be sure the computer is off, and open the computer so that the screen is showing.
    • Use the plastic opening tool and pry away the casing surrounding the screen. Remove the casing entirely.
  2. Samsung ATIV Book 4 Screen Replacement: 2 단계, 이미지 1/1
    • Remove the four 3.5mm screws securing the screen.
    • Tilt the screen back before removing the screws, there is a possibility it could fall and damage your keyboard or the ribbon cable connected to it.
  3. Samsung ATIV Book 4 Screen Replacement: 3 단계, 이미지 1/1
    • Place the screen gently on the keyboard.
  4. Samsung ATIV Book 4 Screen Replacement: 4 단계, 이미지 1/1
    • Remove the ribbon cable from the screen.
    • Remove and replace the screen.
결론
Daniel
회원 가입일: 03/19/15
342 평판
안내서 3개 작성하였습니다
Michigan Tech, Team 1-7, Lauer Spring 2015 Michigan Tech, Team 1-7, Lauer Spring 2015 회원
MTU-LAUER-S15S1G7
2 회원들
안내서 5개 작성하였습니다
댓글 한 개
Where do you buy the replacement screen for the ATIV Book 4? Thanks!
RMS015 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 23
전체 시간: 3,359
