주요 콘텐츠로 건너뛰기
Samsung ATIV Book 9 Lite Battery Replacement
필요한 것
  1. Samsung ATIV Book 9 Lite Battery Replacement, Battery: 1 단계, 이미지 1/2 Samsung ATIV Book 9 Lite Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Battery Replacement: 2 단계, 이미지 1/3 Samsung ATIV Book 9 Lite Battery Replacement: 2 단계, 이미지 2/3 Samsung ATIV Book 9 Lite Battery Replacement: 2 단계, 이미지 3/3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Battery Replacement: 3 단계, 이미지 1/3 Samsung ATIV Book 9 Lite Battery Replacement: 3 단계, 이미지 2/3 Samsung ATIV Book 9 Lite Battery Replacement: 3 단계, 이미지 3/3
    • Using a Phillips #0, remove the seven 5mm screws highlighted in the image.
    • Using your hands, disconnect the battery's main cord from the main motherboard.
  4. Samsung ATIV Book 9 Lite Battery Replacement: 4 단계, 이미지 1/2 Samsung ATIV Book 9 Lite Battery Replacement: 4 단계, 이미지 2/2
    • Using your hands remove the battery from the computer.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Phat Tran
회원 가입일: 09/16/18
786 평판
안내서 5개 작성하였습니다
Washington State, Team S2-G5, Hope Fall 2018 Washington State, Team S2-G5, Hope Fall 2018 회원
WSU-HOPE-F18S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 2개
please where can i get the battery 🔋
Bethel Ugwudike - 답글
Please where can i get the battery for Samsung 930x5j910s5j940x5j
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 21
전체 시간: 1,681
