주요 콘텐츠로 건너뛰기
Samsung ATIV Book 9 Lite Hard Drive Replacement
필요한 것
  1. Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Hard Drive Replacement: 2 단계, 이미지 1/3 Samsung ATIV Book 9 Lite Hard Drive Replacement: 2 단계, 이미지 2/3 Samsung ATIV Book 9 Lite Hard Drive Replacement: 2 단계, 이미지 3/3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Hard Drive Replacement: 3 단계, 이미지 1/3 Samsung ATIV Book 9 Lite Hard Drive Replacement: 3 단계, 이미지 2/3 Samsung ATIV Book 9 Lite Hard Drive Replacement: 3 단계, 이미지 3/3
    • Using your hands or a plastic opening tool, release the yellow motherboard connection strip on both ends by lifting the clamps.
    • Remove the strip to reveal the hard drive.
  4. Samsung ATIV Book 9 Lite Hard Drive Replacement: 4 단계, 이미지 1/2 Samsung ATIV Book 9 Lite Hard Drive Replacement: 4 단계, 이미지 2/2
    • Using a Phillips #0, remove the two 3mm screws holding the hard drive in place.
    • Remove the hard drive by pulling it out with your hands.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Phat Tran
회원 가입일: 09/16/18
786 평판
안내서 5개 작성하였습니다
Washington State, Team S2-G5, Hope Fall 2018 Washington State, Team S2-G5, Hope Fall 2018 회원
WSU-HOPE-F18S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 12
30일 전: 32
전체 시간: 4,544
