주요 콘텐츠로 건너뛰기
Samsung ATIV Book 9 NP900X3K-S01US Bottom Case Replacement
필요한 것
  1. Samsung ATIV Book 9 NP900X3K-S01US Bottom Case Replacement, Bottom Case: 1 단계, 이미지 1/3 Samsung ATIV Book 9 NP900X3K-S01US Bottom Case Replacement, Bottom Case: 1 단계, 이미지 2/3 Samsung ATIV Book 9 NP900X3K-S01US Bottom Case Replacement, Bottom Case: 1 단계, 이미지 3/3
    • Make sure that the Samsung ATIV Book 9 is powered off and not connected to any power outlets.
    • Close the device and rest it on a flat surface.
    • Flip the device over to access the ten 4.3 mm screws located on the bottom case.
    • Remove all ten screws using the Phillips #00 screwdriver.
  2. Samsung ATIV Book 9 NP900X3K-S01US Bottom Case Replacement: 2 단계, 이미지 1/2 Samsung ATIV Book 9 NP900X3K-S01US Bottom Case Replacement: 2 단계, 이미지 2/2
    • Gently lift and remove the bottom case.
결론
Daniella Aloni
회원 가입일: 02/06/19
85 평판
안내서 1개 작성함
UC Davis, Team S18-G1, Lore Winter 2019 UC Davis, Team S18-G1, Lore Winter 2019 회원
UCD-LORE-W19S18G1
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 336
