주요 콘텐츠로 건너뛰기
Samsung ATIV Book 9 Plus Charger Port Replacement
필요한 것
  1. Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: 1 단계, 이미지 1/3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: 1 단계, 이미지 2/3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: 1 단계, 이미지 3/3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Charger Port Replacement: 2 단계, 이미지 1/1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: 3 단계, 이미지 1/2 Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: 3 단계, 이미지 2/2
    • Unscrew the 4.3mm screws holding down the plastic cover using a #000 screwdriver. After the screws are out remove the cover.
    • Remove the 4.3 mm screw holding down the metal cover using a #000 screwdriver.
  4. Samsung ATIV Book 9 Plus Charger Port Replacement: 4 단계, 이미지 1/1
    • Disconnect the charging port from the motherboard by gently tugging on the plastic part of the connection.
  5. Samsung ATIV Book 9 Plus Charger Port Replacement: 5 단계, 이미지 1/1
    • Wedge a plastic opening tool or spudger in between the laptop casing and the port. Pry until you feel it release.
    • This will take some force because the port is glued to the casing.
  6. Samsung ATIV Book 9 Plus Charger Port Replacement: 6 단계, 이미지 1/1
    • Remove the disconnected charger port.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Casey Kauffman
회원 가입일: 11/06/17
329 평판
안내서 2개 작성하였습니다
IUPUI, Team S6-G6, Baechle Fall 2017 IUPUI, Team S6-G6, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S6G6
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 1,934
