주요 콘텐츠로 건너뛰기
Samsung ATIV Book 9 Plus Screen Replacement
필요한 것
  1. Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: 1 단계, 이미지 1/3 Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: 1 단계, 이미지 2/3 Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: 1 단계, 이미지 3/3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Screen Replacement: 2 단계, 이미지 1/1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Screen Replacement, Screen: 3 단계, 이미지 1/1
    • Disconnect the wire connected at the marked location. This is done by giving it a solid tug parallel with the laptop.
  4. Samsung ATIV Book 9 Plus Screen Replacement: 4 단계, 이미지 1/2 Samsung ATIV Book 9 Plus Screen Replacement: 4 단계, 이미지 2/2
    • Unscrew the three 4.3 mm screws by using a #000 screwdriver located on the hinges in both corners of the laptop.
  5. Samsung ATIV Book 9 Plus Screen Replacement: 5 단계, 이미지 1/2 Samsung ATIV Book 9 Plus Screen Replacement: 5 단계, 이미지 2/2
    • Remove the piece of foam that covers two antenna cable connectors.
    • Use the tip of a spudger or a fingernail to pry straight up and disconnect the antenna cable connectors.
  6. Samsung ATIV Book 9 Plus Screen Replacement: 6 단계, 이미지 1/1
    • Now the screen is completely disconnected and can just be lifted off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Casey Kauffman
회원 가입일: 11/06/17
329 평판
안내서 2개 작성하였습니다
IUPUI, Team S6-G6, Baechle Fall 2017 IUPUI, Team S6-G6, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S6G6
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 2,171
