주요 콘텐츠로 건너뛰기
Samsung ATIV Book 9 Plus Speakers Replacement
필요한 것
  1. Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: 1 단계, 이미지 1/3 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: 1 단계, 이미지 2/3 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: 1 단계, 이미지 3/3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Speakers Replacement: 2 단계, 이미지 1/1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: 3 단계, 이미지 1/2 Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: 3 단계, 이미지 2/2
    • The speakers are black, and form a block-like "L" shape around the bottom half of the battery.
    • Lift from the corners of the speakers to remove them.
  4. Samsung ATIV Book 9 Plus Speakers Replacement: 4 단계, 이미지 1/2 Samsung ATIV Book 9 Plus Speakers Replacement: 4 단계, 이미지 2/2
    • After lifting the body of the speaker out of the laptop, you will notice that the top of the speaker is connected to the laptop by cables.
    • Continue removing the speakers by gently squeezing the sides of the white connector.
  5. Samsung ATIV Book 9 Plus Speakers Replacement: 5 단계, 이미지 1/1
    • Gently tug on the white connector in order to remove the speakers.
결론
Karoline DaVee
회원 가입일: 03/20/15
136 평판
안내서 1개 작성함
Baylor, Team 2-3, Grigsby Spring 2015 Baylor, Team 2-3, Grigsby Spring 2015 회원
BU-GRIGSBY-S15S2G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 1,482
